#1 rear wheels rubbing on inner arches
Posted: Mon Nov 28, 2022 5:37 pm
by sulzeruk
My IRS was fully rebuilt and fitted to the car before i bought it. The 2 rear wheels are fouling the inner arches quite badly when fitted. There are 205/70s fitted to the car at present. Any basic things to check on the IRS before I haul it out for a look and check?
Thanks, Alasdair
#2 Re: rear wheels rubbing on inner arches
Posted: Mon Nov 28, 2022 5:57 pm
Inner arches or bump stops......Have a look here...your tyres are wider that Jag spec.....Steve
viewtopic.php?f=3&t=19414&p=157793&hili ... ps#p157793
#3 Re: rear wheels rubbing on inner arches
Posted: Mon Nov 28, 2022 6:32 pm
by Gfhug
You say 205s are fitted at present, if you’ve any plan to change them, why not fit the correct 185s? You’ll not regret it.
#4 Re: rear wheels rubbing on inner arches
Posted: Mon Nov 28, 2022 6:55 pm
by sulzeruk
Hi Geoff, the wheels will be replaced with a shiny new set of MWS wheels and the correct 185 tyres. I had a browse of the forum earlier and see the 185 original size is the one to go for.
Alasdair
#5 Re: rear wheels rubbing on inner arches
Posted: Mon Nov 28, 2022 8:23 pm
by caveman
#6 Re: rear wheels rubbing on inner arches
Posted: Mon Nov 28, 2022 10:21 pm
by Series1 Stu
I have a scabby set of original curly hub wire wheels and ancient Pirelli cross ply white wall tyres that you are welcome to borrow until your new ones arrive. I wouldn't take them out on the road though.
Might make sense if you are somewhere in the Cheshire/Shropshire area.
