#1 chain adjustment - tool or no tool...
Posted: Sun Dec 18, 2022 2:07 pm
that's not really the question.
My engine has the rattling noise at start up idling rpm, which goes away at higher rpm. From information on this forum, I seems like I need to adjust the chain.
Browsing the forum, it looks like a good idea to buy the tool (SBS1265) to make the job easier.
However, having removed the cover and pushed in the pin that keeps the dented wheel in place, I cannot get the pin to go "behind" the dented wheel. It always gets stuck flush with the dented wheel.
I tried
hammering it in with some long screwdriver, but to no avail. The marks on the pin that you can see in the picture are from the screwdriver.
Of course it is possibile that some dirt will have accumulated behind the pin, blocking it flush with the dented wheel.
Reading about wiggling out the pin with some plyers, after putting a rag so that the spring does not disappear inside the engine, seems like an option, but I am not very keen to go this way.
So question, is it "normal" that the pin gets stuck flush with the dented wheel and that the tool is there to assist with pushing in a reluctant pin?
Or the fact that the pin got stuck means that I have no option to remove it and clean the opening before reassembling everything?
Jan
I tried
Jan
