#1 Webcon trigger wheel problems
Posted: Sun Jan 29, 2023 9:39 pm
by Paul bow
Hi guys.. wonder if any one can shed some light in an issue I am having with a trigger wheel from webcon.
The issue is that once set up the sensor sits forwards of the trigger wheel by some 10mm, I’ve checked and double checked but to no avail.. the car is a S2 e type.
Any help gratefully received.
#2 Re: Webcon trigger wheel problems
Posted: Sun Jan 29, 2023 10:44 pm
by bitsobrits
It appears you have enough stud length to fit some spacers behind the trigger wheel which should get you close enough to the sensor.
#3 Re: Webcon trigger wheel problems
Posted: Mon Jan 30, 2023 12:19 am
Or just cut the sensor mount down by 10mm.
#4 Re: Webcon trigger wheel problems
Posted: Mon Jan 30, 2023 5:38 am
by Paul bow
Thanks guys.. you can’t put spacers behind it as the mounting hub centralises the trigger wheel via a lip in the centre, if you move it fwd you will loose this, but yes cut the mount down by 10mm is all you can do, but you’d of thought it was made absolutely to fit? I fancied I had done something wrong ??
#5 Re: Webcon trigger wheel problems
Posted: Mon Jan 30, 2023 7:17 am
Paul bow wrote: ↑Mon Jan 30, 2023 5:38 am
Aftermarket stuff, especially small volume production, sometimes needs modification.
#6 Re: Webcon trigger wheel problems
Posted: Mon Jan 30, 2023 8:54 am
by MarekH
Tooth to sensor gaps are typically about 0.6 to 0.8mm. You can either mount the wheel closer to the sensor or the sensor closer to the wheel.
#7 Re: Webcon trigger wheel problems
Posted: Mon Jan 30, 2023 1:09 pm
by DWW
Maybe the sensor bracket is the wrong way round....
