#1 Blaupunkt Hamburg radio help
Posted: Sat Feb 04, 2023 10:40 am
Hi All.......just picked up an early 60s Blaupunkt Hamburg radio......but dont know if its a worker.....so need speaker attached.....but can find no info on what ohm speaker to attatch snd dont want to blow the o/p on first switch on....there is a 3 way speaker o/p cable. ......so options are 2 x 4ohm or 2 x 8 ohm im assuming......or just one speaker..........your advice please...ps no info on radio re o/p rating and cant find a diagram anywhere. ....thanks....Steve
#2 Re: Blaupunkt Hamburg radio help
Posted: Sat Feb 04, 2023 11:41 am
Found this diagram for a similar model....but it has the same speaker plug as mine......have been told via email from a German Radio supplier that "The Ohm value on vintage Blaupunkt radios always is 4 Ohm."... so im assuming on the plug the one speaker connection would be 4ohm... the 2 speaker connection would be 2x8ohm in parallel......but im doubting my self.....i dont want to blow it on first switch on....thats assuming its a worker anyway :bigrin:
#3 Re: Blaupunkt Hamburg radio help
Posted: Sat Feb 04, 2023 11:48 am
by caveman
Hi Steve,
I’ve been running a Blaupunkt Köln for years now and although my speaker connections are at the side of the radio amp casing, they are of a similar with the three pins. Stereo speakers option had the four pin layout. I’m using 8ohm speakers and purely as these were the slimmest I could find. I did run them initially off the 4 ohm single speaker pins but once I found the correct pins for 2 speaker parallel, it made a big difference. Also wiring speakers in anti phase helped. What I did find out, during my investigations with the Blaupunkt vintage radios, was a warning not to switch radio on without speakers being connected. My pin layout is at the bottom here but same theory. This May help:
Here’s my speakers:
There’s some good information here:
https://www.thesamba.com/vw/archives/ma ... lish_3.jpg
I gained a lot of information from here also:
https://derwhites356literature.com/DerW ... adios.html
http://www.vintageblau.com/installation-.html
#4 Re: Blaupunkt Hamburg radio help
Posted: Sat Feb 04, 2023 11:57 am
If it does not work, want to buy a working one or you want it fixed these people can help:
https://www.chromelondon.com/buy-blaupu ... o-14-c.asp
#5 Re: Blaupunkt Hamburg radio help
Posted: Sat Feb 04, 2023 11:59 am
by caveman
#6 Re: Blaupunkt Hamburg radio help
Posted: Sat Feb 04, 2023 1:06 pm
Thanks for the replies.......dosnt quite answer my speeker ohm rating problem as in the diagram above it mentions 1 speaker 5ohm.....2 speaker in shunt 2.5ohm......anyone have info of the Hamburg speaker rating.....do i actually need to get it right......could i use either a 4ohm or an 8ohm in the one speaker position.....would useing the wrong one blow the o/p......thanks......Steve
PS..found this info in one of the links above...just need same info for 60,s units ......"These mono output radios are designed to run either one or two speakers. Speakers should be 8 ohm through the mid 1970's. Using 4 ohm speakers will damage these 8 ohm radios over time"
#7 Re: Blaupunkt Hamburg radio help
Posted: Sat Feb 04, 2023 2:30 pm
by DWW
As an electrical engineer if you are not sure use 8 ohm speakers for test purposes as the higher ohmsge is safest. In any event switch on on lowest volume setting and avoid high volume especially if yo decide to use 4 ohm rated speakers.
#8 Re: Blaupunkt Hamburg radio help
Posted: Sat Feb 04, 2023 2:33 pm
Thanks Danny.....youve confirmed my thinking for testing with 1 speaker......just need to find out what the radio was designed for...Steve
#9 Re: Blaupunkt Hamburg radio help
Posted: Thu Feb 09, 2023 8:36 am
Just an update.....found a Dutch company that specialises in vintage radios and Blaupunkts.....they confirmed that all vintage Blaupunkts use 4ohm speakers. ......typically these radios have connections for a single or twin speakers. ......for single output use 1 4ohm.........for twin use two 4ohm in parallel. .......Steve https://www.classentials.com/product/bl ... th-module/
