coil, ballast resistor??? 67 with points,
autoalain
#1 coil, ballast resistor??? 67 with points,
Post by autoalain » Sun Feb 05, 2023 2:44 pm
Hi, I have two coils that came with basket case car, no markings on them, how do I know if I need a ballast resistor on one of them?? Thanks Mike.
Jack the lad
#2 Re: coil, ballast resistor??? 67 with points,
Post by Jack the lad » Sun Feb 05, 2023 4:10 pm
In the interests of reliability of your completed car I would think that the cost of a new Lucas coil for it would be a wise investment. Price in the UK would be less than £20. :smile:
#3 Re: coil, ballast resistor??? 67 with points,
Post by Heuer » Sun Feb 05, 2023 4:25 pm
The S1 cars did not use ballast coils, the S2 did.
Andyp_67E
#4 Re: coil, ballast resistor??? 67 with points,
Post by Andyp_67E » Sun Feb 12, 2023 4:11 pm
Jack the lad wrote: ↑
Also if keeping a points system invest in new rotor arm, points and condenser from the Distributor Doctor, or new old stock items, not brand new ones even if they are in lucas packs.
Andy
1967 Series 1 4.2 OTS
Leicester, UK
John G.
#5 Re: coil, ballast resistor??? 67 with points,
Post by John G. » Thu Mar 09, 2023 4:27 am
Hi Mike.
Typically, ballast resistor coils are just over 1 ohm,
non-ballast coils are around 3 ohms.
That’s the one you should use.
Regards.
John Gadbois
'66 E-Type 2+2, ‘64 3.4 MK2
Montreal, Quebec, Canada
