#1 coil, ballast resistor??? 67 with points,
Posted: Sun Feb 05, 2023 2:44 pm
by autoalain
Hi, I have two coils that came with basket case car, no markings on them, how do I know if I need a ballast resistor on one of them?? Thanks Mike.
#2 Re: coil, ballast resistor??? 67 with points,
Posted: Sun Feb 05, 2023 4:10 pm
by Jack the lad
In the interests of reliability of your completed car I would think that the cost of a new Lucas coil for it would be a wise investment. Price in the UK would be less than £20. :smile:
#3 Re: coil, ballast resistor??? 67 with points,
Posted: Sun Feb 05, 2023 4:25 pm
by Heuer
The S1 cars did not use ballast coils, the S2 did.
#4 Re: coil, ballast resistor??? 67 with points,
Posted: Sun Feb 12, 2023 4:11 pm
by Andyp_67E
Jack the lad wrote: ↑
Also if keeping a points system invest in new rotor arm, points and condenser from the Distributor Doctor, or new old stock items, not brand new ones even if they are in lucas packs.
#5 Re: coil, ballast resistor??? 67 with points,
Posted: Thu Mar 09, 2023 4:27 am
by John G.
Hi Mike.
Typically, ballast resistor coils are just over 1 ohm,
non-ballast coils are around 3 ohms.
That’s the one you should use.
Regards.
