Rear Fuel Pipe
#1 Rear Fuel Pipe
Post by mgcjag » Fri Dec 10, 2010 6:43 pm
Hi All.....Whilst the IRS is removed (currently refurbing it) had a scrape around to remove loose underseal/rust, etc & run a wire brush over the fuel pipe that runs over the IRS it almost immediatly sprang a leak, question the pipe is steel....any problems replacing with kunifer? also what size? Thanks. Steve
#2 Re: Rear Fuel Pipe
Post by 1954Etype » Fri Dec 10, 2010 7:30 pm
mgcjag wrote:Hi All.....Whilst the IRS is removed (currently refurbing it) had a scrape around to remove loose underseal/rust, etc & run a wire brush over the fuel pipe that runs over the IRS it almost immediatly sprang a leak, question the pipe is steel....any problems replacing with kunifer? also what size? Thanks. Steve
Shouldn't be any problem replacing with kunifer - just measure the pipe you remove. They are available as a complete (2 part) assembly though. Best of replacing it all the way through if the back part has gone (remember to keep the original as a template though).
Post by mgcjag » Sat Dec 11, 2010 12:05 pm
Any idea of the pipe size? Thanks Steve
JEP41
Post by JEP41 » Sat Dec 11, 2010 11:19 pm
Hi Steve,
When I replaced mine (series 1 OTS lightweight replica) I used 3/8" copper. I wanted to be sure there would be plenty of fuel would feed the webbers :lol:
Also using 3/8" copper on the C-Type Replica I am building
Kind Regards John
kgnich
Post by kgnich » Sun Dec 12, 2010 12:59 pm
mgcjag wrote:Any idea of the pipe size? Thanks Steve
I'm just in the process of replacing some of my fuel pipe on my 1969 2+2. It is 5/16" outer diameter if that helps.
Graham
1969 4.2 2+2
summerscheifer
#6 do i need to buy jaguar parts?
Post by summerscheifer » Wed Dec 15, 2010 7:22 am
hi guys :D had a problem. 1994 Jaguar XJ6 VCM fault code 14 fuel fail, what does it mean?i'm confused.:?: do i need to buy some jaguar parts? :? what would be the problem of it? and other question, has anyone replaced the old steel pipes with the newer pipes as used on modern cars? :?: thanks.
Post by christopher storey » Wed Dec 15, 2010 8:55 am
I'm afraid we are not very knowledgeable about XJ6 on this forum which is only dealing with E types. You would be better asking the question on Jaglovers, although again that deals mostly with older cars than the XJ40 series
#8 Re: do i need to buy jaguar parts?
Post by PeterCrespin » Wed Dec 15, 2010 1:53 pm
summerscheifer wrote: 1994 Jaguar XJ6 VCM fault code 14 fuel fail, what does it mean?i... and other question, has anyone replaced the old steel pipes with the newer pipes as used on modern cars? :?: thanks.
christopher storey wrote:I'm afraid we are not very knowledgeable about XJ6 on this forum which is only dealing with E types. You would be better asking the question on Jaglovers, although again that deals mostly with older cars than the XJ40 series
The Jag-lovers forums deal with pretty much any Jaguar, it's just that pending a software revamp they have stopped making new forums for specific models after about 2003.
Your XJ40 code is from the last system Jaguar used before they switched to the modern on board diagnostics. The Vehicle Condition Monitor (VCM) does a similar job but is not as sophisticated. Fuel Fail 14 means your coolant temp sensder is dud, which will probably cause rich running. Cheap enough to fix. Go to www.jag-lovers.org and look up the XJ40 web forum and maybe look in the archives first.
As it happens, your car's fuel lines may be aluminium, not steel. They certainly were later in 1994 when the X300 came out. Brake pipes were steel if that's what you mean?
['Summerscheifer'? Was bedeutet das? ]
Post by Heuer » Fri Dec 17, 2010 5:07 pm
We done got us a Troll! Seems to have registered on a whole range of car related Forums.
HarryW
#10
Post by HarryW » Fri Dec 17, 2010 7:49 pm
Hi David,
Seasons greetings!!... What's a 'Troll'?
I take it 'Summerscheifer' is in fact 'Winterscheisser' or does my school German let me down? 8)
HarryW
'66 S1 FHC
Post by Heuer » Fri Dec 17, 2010 8:06 pm
Hi Harry
"In Internet slang, a troll is someone who posts inflammatory, extraneous, or off-topic messages in an online community, such as an online discussion forum, chat room, or blog, with the primary intent of provoking other users into a desired emotional response or of otherwise disrupting normal on-topic discussion. In addition to the offending poster, the noun troll can also refer to the provocative message itself, as in "that was an excellent troll you posted". "
HarryW
#12
Post by HarryW » Fri Dec 17, 2010 9:24 pm
Thanks, David.
I should stay in more... :D
HarryW
'66 S1 FHC
