Rubber V-mount dimensions
nefematic
#1 Rubber V-mount dimensions
Post by nefematic » Sun Mar 26, 2023 7:37 pm
I‘m swapping the original US-Differential to a 3.07 unit, the IRS is out. The rubber V-mounts I have are about 8mm higher than the originals. Is this due to the old part settling, or may I have wrong parts? I don‘t mind wrestling them in, but will the added height be a problem once the IRS is back in? The width of the new parts ist 3.5mm wider than the originals, that though is an easy fix with a vise.
OK in the meantime I found this thread that pretty much answers most of my questions, it‘s just hard to install.
Should I look for better fitting parts?
viewtopic.php?t=15799
Martin Scherz
Late S2 1970 OTS US LHD
