For some time now I've been having issues with the high torque starter slow cranking when the car has been laid up for an extended period. I've cleaned up or replaced all the earth connections but this hasn't solved the problem. At all other times the car starts on the button.
More worryingly is the smoking termination on the brown wire at fuse 3! This only happens during the slow cranking and appears to indicate that it's carrying excessive current most likely to the stater motor-a parallel circuit in other words. I've attached a copy of the car's wiring diagram with the offending termination circled. The wiring has been modified over the years with the addition of a 4.2 front wiring harness and additional relays.
I've poured over it in detail but for the life of me can't see any parallel path. Fuse 3 has never blown and none of the other connected wires are affected.
I've ordered a new starter switch from SNGB because the insulation on the brown cables marshalled on it showed signs of heat degradation. I've re-terminated all the affected spade connectors but know this will not have solved the problem.
I'm also going to invest in a CT clamp attachment for my multimeter. This will allow me to monitor the current flow in the brown wire during start up.
I suspect it happens every time the car is started but normally the cranking period is so short that the brown cable can cope with the short burst of high current.
Frankly I'm stumped so any suggestions will be gratefully received.
