SU el electronic faulty
phoenix
#1 SU el electronic faulty
Post by phoenix » Wed Feb 12, 2025 12:27 pm
Hi I have a new {but cant return} AZX1308 electronic fuel pump not working. It makes the usual noise but does not pump .It is on the bench using a good battery. It is 2 years old now so cannot return it. I can take apart but before I do any advice . Thanks
S1 4.2 RHD Bryan
phoenix
#2 Re: SU el electronic faulty
Post by phoenix » Wed Feb 12, 2025 2:49 pm
I have now stripped it and found the three diaphragm intact.
S1 4.2 RHD Bryan
caveman
#3 Re: SU el electronic faulty
Post by caveman » Fri Feb 21, 2025 8:34 pm
Hi Bryan,
See Mareks excellent reply (#6) in following link, it may help understand the technical side of operation:
viewtopic.php?f=3&t=19817
I've had 2 new Electronic SU pumps fail in quick time, one straight out of the box would tick but pressure was poor. Mine were replaced under warranty, thankfully.
1965 S1 4.2 FHC (early)
:wavegreatbritain:
phoenix
#4 Re: SU el electronic faulty
Post by phoenix » Wed Feb 26, 2025 3:12 pm
I am reluctant to buy another SU pump after this on failed virtually out of the box what is the best alternative.
S1 4.2 RHD Bryan
caveman
#5 Re: SU el electronic faulty
Post by caveman » Wed Feb 26, 2025 5:59 pm
I have a third (and final) electronic SU pump fitted this winter, courtesy of SNGB. I'm hoping this one provides longevity. I carry a Facet as a spare, that has been faultless previously, and I also have a HARDI pump, thats a German SU equivalent, so I'm led to believe. I also have a fuel regulator than ensures no matter what pump is fitted, I maintain uniform pressure (2psi).
I'd be interested to hear what others carry as part of their spares in the boot etc? A second £££ SU maybe?
:wavegreatbritain:
Tommd
#6 Re: SU el electronic faulty
Post by Tommd » Wed Feb 26, 2025 10:35 pm
I have had good luck with the original pump.
Tom
