Folks, it appears I may have two senders for oil, one is located rite on top of the oil filter unit,
the other is to the rite of this and down low near the pan, the engine is from a 65 xke and not my 67.
any idea what the lower unit is for??? maybe the warning light? Thanks Mike (basket case)
67 coupe oil sender question
#2 Re: 67 coupe oil sender question
Not quite sure but could be one for the pressure gauge and one for the warning light.
#3 Re: 67 coupe oil sender question
As above.....oil pressure sender that operates the ignition warning lamp.....Steve
