#1 "oddish" engine breather ?
Posted: Mon May 15, 2023 10:22 am
by PierreW
Continuing to review my purchase (1964 3.8l OTS) I came across this!
is this a normal fitment for an E-Type?
or is it from another model?
#2 Re: "oddish" engine breather ?
Posted: Mon May 15, 2023 10:32 am
by Jack the lad
It looks to be the correct breather but it is fitted facing towards the exhaust side of the engine. They usually face towards the inlet manifold side. Where does the pipe connect? Could it be going to an oil catch tank on the left side of the car?
#3 Re: "oddish" engine breather ?
Posted: Mon May 15, 2023 10:38 am
by PierreW
I don't think it's mounted upside down since the ignition coil would be underneath in that case. The tube is in the open towards the end of the engine, no collection container.
#4 Re: "oddish" engine breather ?
Posted: Mon May 15, 2023 10:45 am
by Jack the lad
If it is an open pipe then you will pushing crankcase fumes into the atmosphere, not the best for the planet. The outlet should face towards the carbs and be connected to the air cleaner (air inlet) to be burnt within the engine. Not all E types had the coil attached to the breather, some were mounted on the space frame.
#5 Re: "oddish" engine breather ?
Posted: Mon May 15, 2023 10:53 am
It should mount like this...coil fits in the same place....outlet feeds into air intake...Steve
#6 Re: "oddish" engine breather ?
Posted: Mon May 15, 2023 1:51 pm
Yep, mounted upside down :roll:
#7 Re: "oddish" engine breather ?
Posted: Mon May 15, 2023 3:34 pm
by PierreW
OK thank you all for your precious inputs :smile: :salute:
#8 Re: "oddish" engine breather ?
Posted: Tue May 16, 2023 3:21 pm
by Allrand
You're missing the bracket that mounts the coil & attaches to the top 2 studs of the cyl head breather cover.
#9 Re: "oddish" engine breather ?
Posted: Tue May 16, 2023 8:25 pm
by PierreW
No, no it is present but not really visible on the first picture :-)
#10 Re: "oddish" engine breather ?
Posted: Mon May 22, 2023 6:51 am
by PierreW
I reconstituted the metal bracket that was missing and reassembled everything properly. Problem solved. THANKS! :bigrin:
#11 Re: "oddish" engine breather ?
Posted: Mon May 22, 2023 7:28 am
by RICHOT
Excellent 👍
