#1 Rear bulkhead holes, which one for boot lock
Posted: Tue May 16, 2023 6:44 pm
by Pex
On the rear bulkhead, on the right side…
Can anyone confirm that the cable harness should go trough the lower hole and the boot lock handle in the upper one?
Can’t see that it should be the opposite way.
The reason I ask is that the new bulkhead panel I bought has a cutout that aligned to the lower hole when I expected it to align to the boot lock handle’s upper hole.
#2 Re: Rear bulkhead holes, which one for boot lock
Posted: Sun May 21, 2023 10:38 am
by Jack the lad
Hi Peter,
I have attached a photo of my boot lock and wiring route, the nearside, (left when seated) is the larger of the two cables going to the rear boot area. hope this helps, cheers John.
