BW12 Vacuum Modulator Valve Removal
andrewk
#1 BW12 Vacuum Modulator Valve Removal
Post by andrewk » Tue Jun 06, 2023 3:56 pm
Dear All,
I hope someone can give me a little advice please -
I need to replace my Series 3's vacuum modulator valve from the Borg Warner Model 12 box. I'm fairly sure its failed as I've had a loss of fluid, slip gear on reverse and an acrid smell out of the exhaust.
The problem is I just can't seem to unscrew it from the body of the box, its like it is welded in. I've got a slim enough spanner and I've even dried tapping it with a mallet, however it just won't budge. I'm worried too that too much force might sheer it off.
Any tips or advice will be gladly appreciated.
Kind regards,
Andrew
73, OTS
