Hi, is there supposed to be any sound proofing on the gearbox cover inside the car?
My series 1 2+2 has traces of felt /glue but none of the felt kits I have seen seem to cover this area. I do remember reading something a while ago about ensuring that the felt is not to thick in this area so that the radio consul is not raised too high so the centre section of the dash does not catch as it is swung down.
sound proofing above the gearbox
Stevejaguar
Topic author - Posts: 177
#2 Re: sound proofing above the gearbox
There's a big wad of foam that sits on the top of the box and provides nesting for mice.
I usually put some Dynamat inside the tunnel itself, and inside the cover.
As you say you need to make sure you don't interfere with the console fixing.
#3 Re: sound proofing above the gearbox
1965 S1 4.2 FHC (early)
Stevejaguar
#4 Re: sound proofing above the gearbox
Thanks for the replies. I didn't know of the foam below the transmission tunnel. Is there anything which glues to the top of the gearbox cover inside the car ?
#5 Re: sound proofing above the gearbox
I leave the top painted.
