If the car is lifted on one side and no gear is engaged, is it possible to turn the lifted wheel or is there an immediate blockage? . I tried to turn the wheel which is lifted, transmission shaft turns a little (1/4 of a turn) and after that I can no longer turn the wheel as if a gear was engaged. Is this normal?
If not what would be the other ways to test and if it does not work properly what would be other symptoms on the road?
