Monkeyfinger wrote: ↑Sun Sep 03, 2023 11:28 amSteve, you reminded me that I was working on 3D printing this part a little while ago - I like to copy appropriate plastic components on my car, when I get the opportunity. I can finish working on this, as soon as I get some Lucar connectors with the locking tabs, which are needed to fit inside the plug. I don't believe anything like this is still available (at least I never found one when I was searching). Image shows original on the left, 3D printed version on the right. On my car it's mounted on a fairly short flying lead that has 2 male spade connectors which join the harness on the bulkhead.
They're unlikely to be cooper because copper has very low resilience and won't hold it's shape for any length of time. More likely to be phosphor bronze or maybe even beryllium copper. I doubt either would be available new these days due to cost constraints.Monkeyfinger wrote: ↑Thu Sep 07, 2023 7:38 amI note that the original 6.3mm terminals are copper on my car, but these seem very hard to find these days, unless someone knows a source?
That's sounds like a dumb way of doing things. 4 extra connectors and 6 extra points of failure. Why not just build the connector into the loom?Monkeyfinger wrote: ↑Sun Sep 03, 2023 11:28 amOn my car it's mounted on a fairly short flying lead that has 2 male spade connectors which join the harness on the bulkhead.
