Glue for door and window rubber
rtvet21
#1 Glue for door and window rubber
Post by rtvet21 » Mon Dec 20, 2010 5:27 pm
Has anyone worked out the best glue to fit new door rubbers . I have tried various contact adhesives with little long term use, and with a soft top the rubbers need to be correctly fitted ..Help , Please
daverawle
#2 Re: glue for door and window rubber
Post by daverawle » Mon Dec 20, 2010 5:43 pm
I used Weather Strip adhesive from 3M, it's not easy to find outside of the States but it sometimes turns up on ebay. Beware of the B post rubber sold by a very large Jag parts supplier - they must have worked hard to produce a completely adhesive resistant rubber :evil:
I can recommend the rubber seals from COH Bains
1963 OTS
Post by Heuer » Mon Dec 20, 2010 5:54 pm
Try this stuff: http://www.car-hood.co.uk/content.php?n ... 50&pID=916 - Alphabond 1378
or these: http://www.woolies-trim.co.uk/c-304-adhesive.aspx - the Alphabond AF176 in particular.
Wash/wipe down the rubber seal with switch cleaner or other solvent to remove all traces of MRA (mould release agent) before gluing.
1954Etype
Post by 1954Etype » Mon Dec 20, 2010 6:02 pm
I use Tiger Seal or Sikaflex
Dave K
Post by Dave K » Tue Dec 21, 2010 2:01 pm
I also used Sikaflex so no chance of anything coming off!
pmansson
Sweden
#6 COH Baines
Post by pmansson » Sat Dec 25, 2010 7:40 am
I saw their impressive collection of rubber profiles.
The question is, which do I order for the S1 E-type?
They obviously don?t have a bundled set with all the parts.
The bad ones are the horizontal ones against the lower door edge and the vertical ones against the door?s rear end, at least on my car.
Perhaps the cut ones on the soft top frame, against the door windows.
Merry Christmas !
Peder
daverawle
#7 Re: COH Baines
Post by daverawle » Sat Dec 25, 2010 11:36 am
Peder,
Give them a call and ask for their brochure of Jaguar rubber. I have found them very easy to deal with.
1963 OTS
rtvet21
Post by rtvet21 » Sun Jan 02, 2011 5:17 pm
Many thanks to you all, off to buy the glue and start sticking.......
ps..is there a correct crackle grey paint for the series 2 air filter container ??
thanks
rt
Post by Heuer » Sun Jan 02, 2011 5:50 pm
Hammerite?
