Fresh air intake on bonnet mounting
#1 Fresh air intake on bonnet mounting
I just don't seem to be able to get it high enough not to foul the heater box. Also how were they attached at factory . S1 4.2 rhd
S1 4.2 RHD Bryan
#2 Re: Fresh air intake on bonnet mounting
#3 Re: Fresh air intake on bonnet mounting
Hi thanks Danny . Can you tell me the gap between bonnet .
No rush.
No rush.
S1 4.2 RHD Bryan
#4 Re: Fresh air intake on bonnet mounting
#5 Re: Fresh air intake on bonnet mounting
Danny - looks like you're missing a set of the signature 'ovaloid' washers from under the bolts on your snail (picture taken from the S1 3.8 Factory Original thread):
HTH
HTH
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
Geoff Allam
#6 Re: Fresh air intake on bonnet mounting
Just a caution Bryan. The red car shown has a 3.8
housing. The 4.2 has a different style that has a pad on top so I would assume that the clearance from the bonnet is tighter than 1.5 inches. As for mounting there should be oval washers under the bolts. Look in the originality section. There are good pictures as well as descriptions.
Geoff Allam
Geoff Allam
#7 Re: Fresh air intake on bonnet mounting
Original poster states that he has a 4.2.
Geoff Allam
#8 Re: Fresh air intake on bonnet mounting
"Danny - looks like you're missing a set of the signature 'ovaloid' washers from under the bolts on your snail (picture taken from the S1 3.8 Factory Original thread):"
Thanks Simon, you are right, I shall order a few if I don't have them in my spares box.
Probably this is because I wasn't aware there was a difference in boxes between 3.8 and 4.2.
#9 Re: Fresh air intake on bonnet mounting
Early 4.2 cars had the 3.8 type fiberglass connector box as well. Not sure when the change to the later connector box occurred, but believe it was late '65.
#10 Re: Fresh air intake on bonnet mounting
