#1 ignition light flickers on at idle
Posted: Tue Oct 24, 2023 5:41 pm
Greetings all,
The question is about my MK2, but would also apply to 1961-64 E-Type generator/regulator setups.
1964 3.4 MK2. New generator and voltage regulator.
I’m just making sure the voltage regulator is properly adjusted.
I’ve adjusted the ‘cut-in’ voltage at 13 volts, which happens around 1200 engine RPMs.
I’ve adjusted the cut-out adjustment at 10 volts, which happens at 1000 engine RPMs.
Since the idle speed is around 700 RPMs with 5-6 volts generator output on the WL terminal, I would think it normal to see the ignition light flicker at idle.
Am I correct about this, or am I missing something ?
Best regards.
John G.
Best regards.
John G.
