#1 Small Petrol Leak
Posted: Sun Dec 24, 2023 5:39 pm
Had to leave the ignition on today whilst repairing the reversing lights (about 5 mins) and noticed the fuel pump does not quite stop ticking, perhaps once every 20 secs or so, followed by a smell of petrol.
There is a leak from all three carbs.
On removing the air cleaner there is a pool of petrol coming from the main jet area/ bottom of piston and leaking out under each trumpet. Once the engine is running, then no leaks.
I have checked all floats and valves and they appear to be shutting off correctly.
Anyone else experienced this or should I just not leave the ignition on without running the engine?
Thank you
Thank you
