Manifold studs to head
tim wood
#1 Manifold studs to head
Post by tim wood » Tue Jan 09, 2024 6:27 pm
As I progress with my head overhaul I’m now looking at the studs which secure the inlet and exhaust manifolds to the head. Once removed before the head work some of these had clearly seen better days.
I’ve got a few assorted studs in my parts box all of these along with the existing have 5/16 unf / unc threads
Although I carefully bagged up the studs from each manifold separately it’s obvious that they are a mixed bag of differing lengths.
The SNG website lists c11761 as suitable for both inlet and exhaust and c7624 for the exhaust only.
My question is should the studs all be the same?
Does any difference exist twixt inlet and exhaust ?
What do you use?
What know is that a set of stainless studs is significant cost !
Tim
#2 Re: Manifold studs to head
Post by mgcjag » Tue Jan 09, 2024 7:02 pm
Hi Tim..
.your best off looking at the parts catalogue(knowledge base) for the part numbers.......although it dosnt give lengths.....Steve
#3 Re: Manifold studs to head
Post by Gfhug » Tue Jan 09, 2024 9:51 pm
Aren’t a couple of studs longer, eg on the exhaust where the dipstick clamp attaches? :shrug:
tim wood
#4 Re: Manifold studs to head
Post by tim wood » Tue Jan 09, 2024 10:15 pm
Geoff,
Yes, the parts manual lists differing studs for the gearbox breather, dipstick holder and alternator heat shield.
I’m not sure that these differing studs are available.
I’m going to have a stud sorting session tomorrow!
Buying all new stainless studs is a temptation but costly
Thanks both
Tim
JerryL770
#5 Re: Manifold studs to head
Post by JerryL770 » Wed Jan 10, 2024 7:30 pm
Go to a bolt and nut supplier (like Namrick or Sterling in Peterborough). They stock UNC/UNF studs in all normal material/plating specs.
Jerome Lunt
tim wood
#6 Re: Manifold studs to head
Post by tim wood » Wed Jan 10, 2024 9:18 pm
Thanks all, I reckon it’s sorted now.
