Special Bolt but unknown part number or purpose
gmunro
#1 Special Bolt but unknown part number or purpose
Post by gmunro » Thu Jan 18, 2024 8:46 pm
Hi gents,
I have two bolts, 2 3/8" x 7/16" (possibly UFB 131/19R) with a half depth head, which I set aside whilst stripping the rear suspension. I thought, (as I'm sure many of us have done), that these odd bolts were obvious where they went so I didn't put them in a bag and labelled them! Now I am on the rebuild of the entire rear suspension - diff, wishbones, drive shafts and cage and I now cannot remember where these two bolts go. I have attached a photo of the bolts and hope that any member that my have a suggestion will come back to me with advice. Lesson learned ....... bag 'em and label them !!!
Many thanks and here's hoping some kindly gent or lady will be able to help me and put me out of my misery.
Cheers :banghead:
George
1967 Series 1 OTS
#2 Re: Special Bolt but unknown part number or purpose
Post by Gfhug » Thu Jan 18, 2024 9:13 pm
George, try looking at SNGB for part no C18296. No. 20 on here
https://www.sngbarratt.com/English/#/uk ... %5B7809%5D
Could that be it as it is described as a special, though slightly different length?
And I seem to remember item no 33 is a special bolt, either thin head or similar. Thought is that 1/2 inch?
Your suggestion UFB 131/19R is listed as 5/16 x 2 1/2.
Hope this might help
#3 Re: Special Bolt but unknown part number or purpose
Post by abowie » Thu Jan 18, 2024 10:21 pm
C18296 as Geoff says. Thin head is for clearance.
It also looks a bit like C17149 which is the radius arm bush bolt, but that's 1/2" in diameter, so I think Geoff's right.
#4 Re: Special Bolt but unknown part number or purpose
Post by bitsobrits » Fri Jan 19, 2024 12:00 am
I think they may be for the rear anti roll bar (ARB) drop link bushing to the end of the ARB.
Allrand
#5 Re: Special Bolt but unknown part number or purpose
Post by Allrand » Fri Jan 19, 2024 5:03 am
Radius arm rear bush to wish bone. The thin head is recessed into the wish bone to clear the pivot shaft moulding of the hub carrier. Must be fitted before the hub carrier is connected to the wish bone.
Randall Botha
