#1 3.8 Engine Damper Alternatives
Posted: Mon Jan 29, 2024 12:32 pm
by politeperson
The 3.8l engine damper is like a dinner plate-almost the diameter of a 45 single.
The 4.2l damper has a much smaller diameter.
Anyone know if a 4.2l crank damper will fit a 3.8 engine? This is so I can attach a normal size trigger wheel.
Or will this mess up the harmonics?
James
#2 Re: 3.8 Engine Damper Alternatives
Posted: Mon Jan 29, 2024 5:29 pm
by mtnjag
I believe a later XJ6 damper will fit. Later design.
#3 Re: 3.8 Engine Damper Alternatives
Posted: Mon Jan 29, 2024 10:40 pm
It'll fit OK. Can't answer the question about harmonics.
#4 Re: 3.8 Engine Damper Alternatives
Posted: Tue Jan 30, 2024 1:09 am
by lowact
The older it is, the harder and more brittle the rubber will have become, the less effective it will be …
#5 Re: 3.8 Engine Damper Alternatives
Posted: Tue Jan 30, 2024 2:16 pm
I would be very wary of substituting the later large mass damper for the earlier dinner plate type one. You do not want a fractured crankshaft
#6 Re: 3.8 Engine Damper Alternatives
Posted: Tue Jan 30, 2024 6:29 pm
by mtnjag
I believe it to be a common substitute. Look at all the available High Performance balancers for these engines. None of them have a design like the early ones. Mass seems to be less or same with smaller diameter. Been running one for 25 years on my 3.8 installed by the Jag performance shop that built my engine.
#7 Re: 3.8 Engine Damper Alternatives
Posted: Wed Jan 31, 2024 10:39 am
by politeperson
Thanks for the input.
I think I will try a 4.2 balancer and see what happens.
The rest of the rotating assembly is off to be balanced next week anyway, so I will add this into the mix.
It is amazing what a difference having it all balanced prior to assembly makes to the smoothness of it all.
#8 Re: 3.8 Engine Damper Alternatives
Posted: Thu Feb 01, 2024 10:02 pm
by rfs1957
It’s possible to neatly shrink-fit a much bigger toothed wheel onto the back of the oft-supplied (by UK retailers) ProRace damper, which is actually Australian.
If you search in the Megajolt thread for rfs1957 you should find all the details from when I did it, I would send you the link but am fat-fingers-small-screen in an airport lounge so ………… not tonight.
Much, much neater and more elegant than fitting one on the crank nose.
#9 Re: 3.8 Engine Damper Alternatives
Posted: Fri Feb 02, 2024 6:41 pm
by politeperson
Thankyou Rory, I will have a look.
#10 Re: 3.8 Engine Damper Alternatives
Posted: Fri Feb 02, 2024 6:58 pm
by rfs1957
Details are on Post #425 of the Megajolt thread.
#11 Re: 3.8 Engine Damper Alternatives
Posted: Fri Feb 02, 2024 11:42 pm
rfs1957 wrote: ↑Fri Feb 02, 2024 6:58 pm
viewtopic.php?f=9&t=437&hilit=megajolt& ... 20#p108615
