Could this be the cause?
AndresParker
#1 Could this be the cause?
Post by AndresParker » Tue Jan 30, 2024 5:47 am
After parking my car following a drive, I noticed the ignition key was unusually hot, a phenomenon I hadn't observed before. To investigate, I attempted to remove the chrome ring around the lock, but encountered difficulty due to its two slots on the outer edge. Is there a specific tool required for this task? During the recent trip, I had the fans and side lights on - could this be the cause of the key heating up? The switch and contacts appear relatively new and in good condition.
#2 Re: Could this be the cause?
Post by mgcjag » Tue Jan 30, 2024 9:26 am
What model..Have a look here and follow the links...yes there is a tool or a pair of thin long nose pliers work..Steve viewtopic.php?f=3&t=18775&p=152094&hili ... EY#p152094
max-it-out
#3 Re: Could this be the cause?
Post by max-it-out » Tue Jan 30, 2024 11:10 am
Same thing happened to me , so I bought a new ignition lock and key so I could change it if it burnt out . I also made a tool to unscrew the chrome ring using a small block of wood into which 2 small pins were inserted . :salute:
1968 series 1.5 roadster
#4 Re: Could this be the cause?
Post by DWW » Tue Jan 30, 2024 4:36 pm
I had that happen to me too. The best solution I found was to install an ignition relay so the ignition key switch doesn’t take the entire current the car consumes. A 40A relay is required as result the key only activates the relay with minimal current.
caveman
#5 Re: Could this be the cause?
Post by caveman » Tue Jan 30, 2024 7:42 pm
1965 S1 4.2 FHC (early)
:wavegreatbritain:
#6 Re: Could this be the cause?
Post by cactusman » Tue Jan 30, 2024 8:38 pm
Considering most folk may need the tool maybe once a year (lifetime!) max I would simply make one from a thin (1 mm thick) sheet of steel suitably notched and filed at the top as £28 for the flashy knurled one....really!
Or as others have suggested...thin long nose pliers or circlip pliers!
Mich7920
#7 Re: Could this be the cause?
Post by Mich7920 » Wed Jan 31, 2024 11:37 am
Don't you have simply the "hot key" syndrome ?
viewtopic.php?f=9&t=6885&hilit=Ignition+relay
I had this and put a relay as explain. Work fine now.
Mich
Michel
Paul bow
#8 Re: Could this be the cause?
Post by Paul bow » Sun Feb 04, 2024 7:57 pm
I had exactly this.. in fact the key got so hot it burned my hand to a blister getting it out!
It turned out to be feedback on the wiring loom ..
Nothing to do with the ignition barrel or key.
S1 2+2 manual. (Sold)
