Has anyone any experience with the uprated Goodridge cam feed pipe washers offered by SNGB?
They look significantly thicker than the original paper thin copper washers with the compression ring and
I am concerned about fitting them and finding the oil feed holes don’t line up properly.
Thank you
Cam feed pipe washers
SimonBrown
Topic author - Posts: 197
#1 Cam feed pipe washers
Simon Brown
1969 E Type Series 2 OTS
2013 F Type V6 Convertible
1975 Honda 400 Four
1975 Honda 400 Four
#2 Re: Cam feed pipe washers
HI Simon
You are welcome to borrow my goodridge washers and compare them to your banjos, they look OK on mine but I have thicker copper washers on already. I won't be needing mine for 2 weeks at least, so if they look OK then use them and order me some more.
Ian
Ian
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
2016 Caddy van
SimonBrown
#3 Re: Cam feed pipe washers
Thanks Ian,
I’ll mail you
I’ll mail you
Simon Brown
1975 Honda 400 Four
1975 Honda 400 Four
