Fuel line material
16024d
#1 Fuel line material
Post by 16024d » Sat Apr 06, 2024 7:29 am
What type and size fuel line is used on early cars. I understand its while nylon but is it PA10 PA6 or PA12?
Mich7920
#2 Re: Fuel line material
Post by Mich7920 » Thu Apr 11, 2024 11:30 am
SNG BARRATT:
FS1001 ..... Fuel Line/metre
Michel
#3 Re: Fuel line material
Post by Heuer » Thu Apr 11, 2024 1:24 pm
And when you come to fit it to the banjo's be prepared for a fight. Tip: heat up the fitting, not the pipe, hold it in a vice and push the pipe on.
265bhp
#4 Re: Fuel line material
Post by 265bhp » Fri Apr 12, 2024 6:34 pm
To echo David, immersing the nylon pipe end in a mug filled with hot water from a boiled kettle worked well for me….its not easy….but it will work
16024d
#5 Re: Fuel line material
Post by 16024d » Wed Apr 17, 2024 9:59 am
Thanks for your help. Will purchase from sng
