HS8 question.
genneton4
#1 HS8 question.
Post by genneton4 » Mon Apr 01, 2024 8:06 am
Hello. I wondered if I could ask a question about an XK120 here for the E type oracles. ?
I have an E type going very well but am currently tinkering with the XK120.
I have fitted 2" HS8 carbs and I am disappointed with the low down torque (ie off the line power) they have delivered. They are quite a bit better higher up the rev range but I really wanted to improve the off the line power.
It is a 3.4 with an SE head (not C type), both inlet ports reamed to 2". The engine was rebuilt 1000 miles ago. I have trumpets with foam covers. The needles are standard XJ6 BAW. Powerspark ignition.
Is there any way I can dig myself out of this hole. ? Maybe retard the ignition a tad ? Different needles ?
Any wisdoms gratefully received.
Keith
Present - Series 1.5 FHC 1968, Opalescent Silver Grey - Illinois car.
2009 - Series 1 FHC 3.8 1963, Opalescent Maroon - Dutch ex USA car used in France.
1995 - Series 1 FHC 3.8 1962, Carmen red - from E Type Centre as was.
#2 Re: HS8 question.
Post by mgcjag » Mon Apr 01, 2024 8:30 am
Hi Keith...JagLovers has a very good XK forum.. Steve https://forums.jag-lovers.com/c/xk/28
#3 Re: HS8 question.
Post by abowie » Mon Apr 01, 2024 1:05 pm
There's not really an easy subjective answer to this.
I fitted a 4.2 engine to my Mk2 with the same double HS8 XJ6 setup that you have.
I then had the car tuned on a rolling road dyno. I think that this would be your best option too.
genneton4
#4 Re: HS8 question.
Post by genneton4 » Wed May 22, 2024 9:12 am
Just for closure.
Fitted a 123 ignition on curve 4 - all is well.
I think the Powerspark dizzy I had fitted (from Ebay) has a faulty vacuum.
Simonpfhc
#5 Re: HS8 question.
Post by Simonpfhc » Wed May 22, 2024 12:20 pm
As a matter of interest Keith, which 123 have you fitted - the standard GB one or the XK one?
Glad you have it all sorted.
62 3.8 FHC
91 Porsche 928GT
genneton4
#6 Re: HS8 question.
Post by genneton4 » Fri May 24, 2024 7:21 am
I have the GB one.
Simonpfhc
#7 Re: HS8 question.
Post by Simonpfhc » Fri May 24, 2024 11:16 am
Appreciated Keith, thanks.
62 3.8 FHC
91 Porsche 928GT
