#1 Inaccurate oil dipstick reading
Posted: Thu May 09, 2024 3:07 pm
Hello,
I am the excited new owner of a lovely and very original 1965 FHC. I'm looking forward to introducing myself and getting to know you all but first I have a pressing problem that I hope you can help me with.
When I first checked the oil the day after picking up the car (about a 30 mile drive), the level showed halfway between the hash marks and the 'E' marked at the bottom of the dipstick. Before I picked it up, the level was about half full. Since then, I have only driven it another 30 miles or so. I topped the level with about half a litre of oil. When I checked the oil after it had settled, I obtained an even lower reading with the oil only just reaching the E on the dipstick! There is no oil underneath the car. The car is parked pointing downhill so I took it for a brief drive to find somewhere flat but the reading was exactly the same. I have waited overnight to really allow all of the oil to sink back into the sump but the reading is still the same.
I have been searching on the forum for any advice about this. From what I have read, it sounds just like the symptoms someone had with a bent dipstick that apparently allowed the dipstick to slip across the top of the baffle(?) rather than drop straight into the sump. Once they straightened it, the reading was fine.
The first time I tried to check the oil I really struggled to find the right angle to allow the dipstick to enter all of the way. Looking at my dipstick after reading this, I notice a very minor bend, although nothing like the photo of the bent dipstick I read about, so I made mine as straight as possible but this has made no difference to the reading.
Is there any special technique, angle or turn to make in order to get the dipstick to enter the sump correctly? Or is there something else going on? I have tried 30-40 times now, poking around and using different angles to no effect. It seems happiest going in if I drop down from the right side (towards the windscreen) of the dipstick holder and it goes all the way down but the reading is still the same.
Oil pressure is fine. Any advice you can give is hugely appreciated - I am concerned about driving it without knowing how much oil is in it and I don't want to overfill it if it was okay to begin with! Thank you.
