#1 1961 Won't Start
Posted: Wed Jun 12, 2024 6:13 am
by MattF
Hi all,
My 61 OBL car won't start.
The ignition light is on, I've checked for a spark and can't see one. How can I check the coil or if one of distributer leads is faulty? Battery and fuel are fine.
Had it for three years and never had a problem.
I would really appreciate any advice.
Many thanks,
Matt
#2 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 8:38 am
by malcolm
If one distributor lead to the plugs was faulty, it wouldn't stop the spark at all of the plugs. It could be the king lead, from coil to distributor. You can check that with a multimeter by checking continuity at the ends.
More likely coil, rotor arm or dizzie.
Coil and rotor arm (get a red one form the dizzie doctor) are both dead cheap, so start with them if the king lead is ok.
You'll probably get better advice from others soon!
#3 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 8:45 am
What actually happened?....has it been running recently..when did it run last.....does it turn over quick but just dosnt fire? Do you have 12v at the coil when ignition is switched on?...is there fuel seen at the filter?
#4 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 9:06 am
No spark.
Symptom: car won’t start or run at all.
NOTE: assumes NEGATIVE earth, points in distributor.
To Confirm: Put a plug tester in series with a plug. It should flash when engine is cranked. If no flash check other plug leads as well. No flash = no spark.
If you do have a flash the problem is NOT spark per se, although it MAY be plugs. See 9.
Otherwise the problem may be timing, or fuel or compression. These steps will not help those things.
Take each step one at a time, in order. At the end of each step try to start the car.
1. Battery flat.
If the car cranks over it is almost certainly OK.
2. Engine earth.
Spark requires a good earth to the negative terminal of the battery. Check that the engine is earthed with an ohmmeter or voltmeter between the battery and the block.
Visually inspect the engine earth lead (LHS behind the reaction tie plate. If in doubt run a thick cable (jumper lead) from the battery negative terminal to the engine.
3. Check power to coil.
Remove the positive connector to the coil. Put a 12v test light in series and turn on the ignition. The light should come on and be steady.
Jiggle ignition key to eliminate switch fault.
If no power, run a wire directly from the positive battery terminal to the positive coil terminal and try ignition. If it works problem is between battery and positive terminal wire. Check fuse 7 and chase wiring with multimeter. Recheck ignition switch. NB starter button will not affect spark.
4. Check points are opening and distributor is turning.
You can do this visually. Remove dizzy cap and get someone to crank the engine. You should see the points open and close. Use a torch; it’s dark down there.
Put a 12v test light between the negative coil terminal and the black/white wire to the distributor. Crank the engine. The light should flash off and on as the points open and close. This should work with electronic ignition modules as well because what you are testing is the circuit through the points (mechanical or electronic) to earth.
Note: the light may stay on or off when not cranking depending on whether the points stop closed (likely) or open (unlikely). This isn’t important.
Check the points gap (14 to 16 thou) and inspect the electrode faces for pitting. If any doubt replace points and reset gap. Even when you’re sure it’s not the points, suspect them. It’s always the points.
5. Condenser.
A dead condenser looks just like a good condenser. Just replace it. They can be tested with an ohmmeter but if you put a new one in and it doesn’t fix the problem it probably isn’t the condenser.
6. Check the coil.
If the points are working and the condenser is OK. Get a spark plug and a plug lead. Connect the plug lead into the HT coil connector. Earth the plug by resting it next to a head nut. Turn on the ignition. Use a nonconductive (plastic) tool and open and close the points manually. (Alternatively you can connect a wire to the negative LV connector and tap this on an earth.) There should be a spark on the plug each time the points open. If you have spark the coil is OK. Move on to 6.
If NO spark AND you are happy with 1-4 above, the coil may be faulty. Check the resistance of the low voltage (primary) circuit by connecting an ohmmeter to the two LV terminals. This should be between 0.5 (low resistance/sports coil) and 3.5 ohm (standard coil). Check the HT (secondary) circuit resistance by measuring between either LV terminal and the centre HT terminal. This should be in of the order of 5000 to 15000 ohm. Note that coil failure can be exacerbated by heat so even if it checks out cold it may be faulty hot.
Replace the coil anyway with a known good one. (You can just sit one next to the old one and connect the 3 wires to it).
7. Leads
Remove the coil HT lead. Inspect for cracking or corrosion. Coolant can leak from the thermostat housing down onto the top of the cap and cause corrosion, especially with “screw in” contacts.
Check resistance with ohmmeter; it should be virtually zero with copper core wires.
Check the resistance of each of the plug leads by removing the plug cap and using a multimeter between the end of the wire and the corresponding contact inside the distributor cap. With copper core wire it should be virtually zero. If not check the cap socket for corrosion.
Modern cable resistance is more complex and you would need to check the figures with the manufacturer. As a general guide though a lead should be between 2000 and 8000 ohm.
8. Plug caps
The original plug caps have a carbon resistor in them. They will have a resistance somewhere between 5000 and 15000 ohm. Modern or reproduction caps should be spot on 5000 ohm. If you suspect the caps, replace or eliminate them. You can solder a ring connector onto a fine 1” self-tapping screw. Screw this into the lead in place of the plug cap. Use the ring connector to connect directly to the threaded end on the spark plug.
9. Spark plugs.
Remove the plugs. Check for fouling and check gaps. If no success, replace with new plugs.
10. Distributor cap
Inspect for cracks or corrosion. The cap really should look brand new inside. Clean up the lead connector sockets if at all corroded. The central contact for the rotor button should have a resistance of the order of 30000 ohm. If the cap looks OK still try replacing it with another one, or a known good cap and set of leads.
11. Rotor button
Inspect and replace if it looks worn, pitted, burnt or otherwise faulty. Try another one anyway if it looks OK.
12. Distributor
Remove the distributor and carefully inspect it. Ensure that it wired correctly. Specifically check the insulators between the points and the coil and capacitor leads are in the correct place.
Check that that the coil lead is connected and conducts to the capacitor lead.
Check that the internal earth lead is connected to the distributor body and the centre plate.
Check that the distributor turns freely and is mechanically intact.
Check that there are no small screws or other foreign parts loose inside or causing a short.
13. Other things
If you have got here and not fixed the problem.
The checklist above is fairly complete. Sometimes though electrical components can look OK but be faulty. Replacing each component, one at a time, with a known good (not necessarily new) component will sometimes smoke out a mystery.
#5 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 10:49 am
by MattF
Was running fine earlier this year, its turning over but just not firing now. I'll check on the other bits!
#6 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 10:50 am
by MattF
No spark.
Super helpful, thank you!
#7 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 11:44 am
Hi Matt...please don't quote a whole post.. it just takes up server space...just reply like your haveing a chat...or select and edit if needed....iv edited your posts above..Steve
#8 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 11:50 am
by MattF
Apologies.
#9 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 12:59 pm
by malcolm
He has stated in original post that there was no spark
#10 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 1:44 pm
Hi Malcolm...poster said he can't see a spark....but where was he looking....at one plug lead....at the king lead...at the actual points....he needs to start narrowing it down as per Andrews list....Steve
#11 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 2:51 pm
by Gfhug
I suggest everyone should print out a copy of what Andrew has written above and keep it in their car(s).
#12 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 8:05 pm
by cactusman
The only observation to Andrews excellent list is regarding resistance caps. Original caps had a carbon slug (carbon rod) for an approx 5000 ohms resistance..I dismantled one to check.
Cheap repro caps use a metal oxide resistor...again I dismantled one to check. Metal oxide resistors in HT circuits fail in time...small sparks jump between the turns on the metal film cut into the ceramic rod which erodes the film and thus the resistance goes up...I've had caps that started at 5000 ohms but three months down the line were 250,000 with a consequent misfire.
If your caps are all precisely 5000 (or 10000) ohms bin them...they will fail....sooner or later...ask me how I know?At least one supplier does sell copies with carbon slugs...carbon rod is excellent in HT circuits. However they will be 5000 ohms plus or minus probably 20%...that is what you are looking for. For HT suppression exact resistance is not needed and 20% either way is just fine...
#13 Re: 1961 Won't Start
Posted: Wed Jun 12, 2024 11:28 pm
This is a known problem with the repro Champion bow tie caps. They quickly failed in this manner.
I'm not sure whether they have fixed this as I stopped using them.
I went to using caps made by NGK which were good, however NGK have recently stopped making them
#14 Re: 1961 Won't Start
Posted: Thu Jun 13, 2024 8:05 am
by cactusman
Exactly...the cheap repro bowtie caps use metal film resistors....hopeless..SNGB do repro caps and say theirs are carbon....so far so good!
