Stub Axle Ring
gerry59
#1 Stub Axle Ring
Post by gerry59 » Thu Aug 01, 2024 8:25 pm
Hi Guys
Looking for a little advice on how to remove the stub axle ring so i can fit the new uprated ball joint, on my Series 11 E-Type
Your help would be much appreciated.
Gerry.
tim wood
#2 Re: Stub Axle Ring
Post by tim wood » Thu Aug 01, 2024 8:43 pm
Simple really.
Using a small drift tap it out from the top. ( once you have removed the old ball joint )
Access from inside the hub carrier
gerry59
#3 Re: Stub Axle Ring
Post by gerry59 » Fri Aug 02, 2024 7:36 pm
Thanks Tim Will Try That
