Hi Guys
Looking for a little advice on how to remove the stub axle ring so i can fit the new uprated ball joint, on my Series 11 E-Type
Your help would be much appreciated.
Gerry.
Stub Axle Ring
#2 Re: Stub Axle Ring
Simple really.
Using a small drift tap it out from the top. ( once you have removed the old ball joint )
Access from inside the hub carrier
