#1 Courtesy light switch fittig
Posted: Mon Sep 02, 2024 2:16 pm
by phoenix
S1 FHC.
I am trying to fit the switches I purchased from well known supplier and they do not seem to be able to grip the tube where they fit. Also they don't seem long enough and do not operate. I.e.
Light stays on when doors closed.
,(I have fitted the small striker plate).
#2 Re: Courtesy light switch fittig
Posted: Mon Sep 02, 2024 5:15 pm
by DWW
#3 Re: Courtesy light switch fittig
Posted: Mon Sep 02, 2024 9:08 pm
by Series1 Stu
Bryan,
I think there should be 2 of the small striker plates on each side (4 in total).
#4 Re: Courtesy light switch fittig
Posted: Tue Sep 03, 2024 7:28 am
by Allrand
Had the same problem, typical repro parts from the usual suspects.
#5 Re: Courtesy light switch fittig
Posted: Tue Sep 03, 2024 10:23 am
by Series1 Stu
Agreed, I have a pair of new reproduction switches in my surplus parts box because I accidentally found the original switches and they were so much better in every sense.
#6 Re: Courtesy light switch fittig
Posted: Tue Sep 03, 2024 5:48 pm
by andrewh
Very often 2 chrome plates are fitted to make the distance correct. The reproduction switches need the spring retainer squashing with pliers to make them fit. However, I also found my originals and went with those.
#7 Re: Courtesy light switch fittig
Posted: Fri Sep 06, 2024 3:27 pm
by phoenix
#8 Re: Courtesy light switch fittig
Posted: Sat Sep 07, 2024 8:20 am
by Allrand
How are those fitted, there's no access from inside the A post?
#9 Re: Courtesy light switch fittig
Posted: Sun Sep 15, 2024 4:37 pm
by Series1 Stu
This is what they should look like.
These ones came from Martin Robey.
