#1 Ventilated discs for Volvo calipers.
Posted: Fri Oct 04, 2024 5:33 am
I've been reading the caliper upgrade thread on JL.
A while back I got a set of Volvo 240 calipers for a 24mm ventilated disc.
Try as I might I never found a suitable front disc with the correct hole pattern, thickness and offset to use with S1 E Type/MK2 front stub axles.
Has anyone solved this problem and if so what disc did you use?
I know that you can do this because I have this setup on my S1 4.2 Coupe, but the PO is no longer with us so I can't ask him where he got them from.
#2 Re: Ventilated discs for Volvo calipers.
Posted: Fri Oct 04, 2024 7:29 am
Hi Andrew...if you dont get an answer you could measure the disc..then contact Brembo or other brake provider...they could possibly look up the dimensions..or just troll through the technical drawings on some of their sites....Steve
#3 Re: Ventilated discs for Volvo calipers.
Posted: Fri Oct 04, 2024 9:19 am
Yeah, tried all of that.
#4 Re: Ventilated discs for Volvo calipers.
Posted: Fri Oct 04, 2024 9:43 am
Hi Andrew..have you seen this thread it mentions trimmed down S2 discs https://forums.jag-lovers.com/t/e-type- ... type/70920
#5 Re: Ventilated discs for Volvo calipers.
Posted: Fri Oct 04, 2024 10:59 pm
by mxke
#6 Re: Ventilated discs for Volvo calipers.
Posted: Sat Oct 05, 2024 1:15 am
Yes. The S2 discs aren't ventilated. You do need to turn the discs down to 273mm diameter.
#7 Re: Ventilated discs for Volvo calipers.
Posted: Sat Oct 05, 2024 2:02 am
Does this help?
https://www.allrotors.com/brake-parts-search.php
Yes. Still haven't found a suitable disc yet (although 2 close ones).
This is a lot better than manually searching through catalogs.
#8 Re: Ventilated discs for Volvo calipers.
Posted: Sat Oct 05, 2024 10:30 am
Hi Andrew...have a look at a S2 xj6 ventilated disc...Steve
#9 Re: Ventilated discs for Volvo calipers.
Posted: Sun Oct 06, 2024 8:03 am
That looks pretty bloody close!
#10 Re: Ventilated discs for Volvo calipers.
Posted: Sun Oct 06, 2024 8:19 am
Hi Andrew...S3 xj6 are very similar in not the same as the S2 so have a check....they are also similar to S3 E type disc
#11 Re: Ventilated discs for Volvo calipers.
Posted: Mon Oct 07, 2024 2:07 am
I had a look, and S3 E type has the same disc as S2 XJ6 etc. For some annoying reason they changed the hole spacing from 114.3mm to 111.1mm
I have a set of S3 E Type discs that I machined down to size but I'm not sure if I'm game to drill more holes in it.
I'll keep looking though.
I contacted one of our local suppliers about a replacement set of discs to fit my coupe which has the ventilated Volvo calipers. They say they get them made and a pair is $500.
#12 Re: Ventilated discs for Volvo calipers.
Posted: Wed Oct 09, 2024 6:42 pm
by Jack the lad
Hi Andrew, if the only problem you now have is the PCD for the wheel studs, it is a simple fix for any machine shop. Just a matter of filling the old disc holes by either threading them and fitting threaded slugs OR welding them up. Any machine shop with a vertical miller can then drill new holes for you using the PCD programme that is built into their Digital X, Y, Z measuring system on the machine. A simple and cheap job, if you were local to me I could do it for you. regards John.
#13 Re: Ventilated discs for Volvo calipers.
Posted: Thu Oct 10, 2024 12:07 am
Thanks Jack.
I've got a pretty comprehensive machine shop myself and I can do what you describe.
However I'd be happier of I can get discs with the correct hole spacing.
I do actually have a set on my 4.2 coupe but it's in storage off site and I'm currently recovering from some surgery so I can't access it.
#14 Re: Ventilated discs for Volvo calipers.
Posted: Thu Oct 10, 2024 8:00 am
by Gfhug
And did you insist on being your own anaesthetist?
Get well soon
#15 Re: Ventilated discs for Volvo calipers.
Posted: Thu Oct 10, 2024 8:41 pm
It's a funny game here.
Adelaide's relatively small, so the guy who gave me my anaesthetic has done so before, and I've anaesthetised him as well.
#16 Re: Ventilated discs for Volvo calipers.
Posted: Thu Oct 10, 2024 9:47 pm
by Gfhug
And your choice today is…… ether or whisky :bigrin:
#17 Re: Ventilated discs for Volvo calipers.
Posted: Fri Oct 11, 2024 12:07 am
Yes. It's an ether or situation...
#18 Re: Ventilated discs for Volvo calipers.
Posted: Fri Oct 11, 2024 8:45 am
by rfs1957
My mate is an oncologist, succumbed to his speciality, and ended up being “charcuté” (from charcuterie, geddit) by the people he had himself trained to do that ……
Getting even with your teacher using a knife ?
I’ve seen that elsewhere.
