#1 Gear lever vibration
Posted: Sun Oct 27, 2024 7:45 am
Hi. I had the engine (4.2) and gearbox (4 speed synchro) of my FHC rebuilt when the car was restored and it has a few irritating faults:
1. The gear lever vibrates which causes the chrome bezel on the gator to rattle against the gear lever shaft. The gearbox works smoothly and I have removed the noise by attaching a rubber washer to the inside of the chrome bezel, but would like to sort it properly if possible.
2. The gear lever moves slightly under torque forwards and back by approx 0.5 to 1”.
3. The clutch is heavy - it was fitted new when the box was refurbished along with slave and master cylinders, but is nowhere near as light as my previous S2.
I have checked the engine mounts, engine stabiliser and belt tension in case these were leading to engine vibration referred through the gearbox, but this didn’t make any difference. In addition the gearbox spring has been replaced in case this was too spongy, but again no difference. Any ideas on what may be causing the vibration and lever movement most welcome. Thanks in advance.
Martin
Martin
