Fuel tank, repair
Iansparky
#1 Fuel tank, repair
Post by Iansparky » Sat Nov 30, 2024 5:59 pm
Does anybody have any experience of Por 15 fuel tank sealer, I pulled my tank today to replace the perished boot drain hose, sure enough the felt pad under the tank was wet and had corroded the bottom of the tank, I've got about 3 pin holes in it, is it best to replace with new or go down the sealant route
Ian
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
#2 Re: Fuel tank, repair
Post by Gfhug » Sat Nov 30, 2024 6:49 pm
Have you searched on here for “POR”? Try that first and you can then search within the results for the word “tank”.
You may have found a few pin holes, but how close is the rest of the tank or even the local area to developing more of them? If you go down the route of replacing the tank, search on here for some of the comments to help make getting it into the boot easier, or should we say less difficult.
#3 Re: Fuel tank, repair
Post by mgcjag » Sat Nov 30, 2024 6:50 pm
If you want best then its obviously a new replacement.
#4 Re: Fuel tank, repair
Post by Series1 Stu » Sat Nov 30, 2024 10:58 pm
:yeahthat:
Although, I gave my new tank the POR15 treatment before installing it, just to make sure there is no exposed steel inside it.
Simonpfhc
#5 Re: Fuel tank, repair
Post by Simonpfhc » Sun Dec 01, 2024 9:50 am
I’ve used it on three tanks now. Two worked perfectly and one completely failed. On the one that failed, the final sealing paint just peeled away from the internal surface - preparation is key!
On reflection, I think for the cost of the repair kit, I would buy a new tank.
62 3.8 FHC
91 Porsche 928GT
#6 Re: Fuel tank, repair
Post by mgcjag » Sun Dec 01, 2024 10:00 am
The tank has to come out anyway to seal it....and you will never be sure that after its done that it won't start pealing off....Steve
paydase
#7 Re: Fuel tank, repair
Post by paydase » Sun Dec 01, 2024 11:25 am
Any experience whether rust (pin holes) usually comes from the outside, and in the drain place (due to e.g. wet pad), or more from the inside, and at the front bottom part (due to water condenstation in gas)?
Serge
1964 (3.8) FHC
1961 OTS
Iansparky
#8 Re: Fuel tank, repair
Post by Iansparky » Mon Dec 02, 2024 5:57 pm
My rust has definitely come from the outside from sitting on a wet pad, I rang Hutsons today who said the new tanks are galvanised, I will probably go down the new tank route although a radiator company in Wolverhampton said they could clean the tank and weld new steel into the rusted area, they didn't recommend sealers though, said they had seen too many fail
Ian
1965 series 1 ots
2016 Caddy van
James997
#9 Re: Fuel tank, repair
Post by James997 » Thu Dec 12, 2024 7:25 pm
If the rust is from external moisture and the tank's basically compromised, a new tank is probably your safest bet. Those pin holes suggest more damage might be developing.
