#1 Cylinder Head Nut Torque Spec E-Type Series 2
Posted: Tue Feb 18, 2025 9:09 am
Hi Folks,
Quick question on the correct cylinder head nut torque for a 1969 Series 2 E Type, it's the long stud block so after 7R1916 engine. In Haynes it says 54 lb/ft but maybe 58 lb/ft if you are using a composite gasket (I'm using a Payen composite gasket). However in a Jaguar service bulletin in January 1970 it said 50lb/ft for these engines. Anyone know the right answer, thanks in advance.
Rob.
Rob.
