#1 Protective sleeve for wiring loom body tags - size & sourcing?
Posted: Mon Mar 17, 2025 9:08 am
by rdaustin
We are just routing the loom and have some of the original protective sleeves/sheath that slide over the body tags that hold the loom in place. However, they are stiff and brittle so we want to replace them. We think they should be 9.5mm or 3/8" (internal diameter) - does anyone know where we can source these in the UK? We can find 9mm or 10mm ID sleeving, but not 9.5mm. Also, has anyone tried using 9mm - did it work or was it too tight? Thanks! Rebecca
#2 Re: Protective sleeve for wiring loom body tags - size & sourcing?
Posted: Mon Mar 17, 2025 10:13 am
I usually use heat shrink.
#3 Re: Protective sleeve for wiring loom body tags - size & sourcing?
Posted: Mon Mar 17, 2025 10:38 am
by rdaustin
Thanks Andrew. Does the heat from the hot air gun affect the body paint? (We only got the shell back from the painters about 6 weeks ago). All the best, Rebecca
#4 Re: Protective sleeve for wiring loom body tags - size & sourcing?
Posted: Mon Mar 17, 2025 10:46 am
by 40GT
PVC wiring sleeve, this item isn't expensive and different sizes could be ordered just in case, without a piece to hand I would guess the 8mm ID would flatten to the correct size though.
Edit, ahh I see they don't do an in between size from 8 - 10 mm.
https://www.ebay.co.uk/itm/132361145900 ... BM4umMu7Rl
#5 Re: Protective sleeve for wiring loom body tags - size & sourcing?
Posted: Mon Mar 17, 2025 11:28 am
Dosnt take much heat to shrink...you can use a soldering iron just sliding along it....try a piece...Steve
#6 Re: Protective sleeve for wiring loom body tags - size & sourcing?
Posted: Mon Mar 17, 2025 8:50 pm
rdaustin wrote: ↑
No.
#7 Re: Protective sleeve for wiring loom body tags - size & sourcing?
Posted: Mon Mar 17, 2025 10:39 pm
by rdaustin
Thanks everyone for the advice - very helpful :)
Now the fun part of deciphering what all the wires are for., and which bits go through which holes on the body.. have bought the Cov Auto Components guide to help
