#1 Rear Main Oil Leak
Posted: Sat Jul 19, 2025 8:54 am
My S2 OTS has been plagued with an oil leak from the rear main for years now.
It leaks only when thoroughly hot after a motorway run but is dry in normal day to day use.
The crank has been ground to fit the Terrys oil seal conversion, and checked to be dimensionally correct, also fitted with a new Terrys seal, still the leak persists.
I have always run it with a quality 20w50 oil
I have checked actual oil pressure at motorway speeds and for crank case pressure. It does not appear crank speed related as it will start to leak after about 20 mins constant speed driving at 50-60mph.
As the leak only starts in these conditions (and to avoid pulling the engine again and obtaining another crankshaft) would anyone have any suggestions?
Would it be worth trying a 20w60 oil that may remain more viscous at higher temperatures?
Appreciate any help
Appreciate any help
