What is this part?
dmarsh2426
#1 What is this part?
Post by dmarsh2426 » Fri Jul 25, 2025 6:56 pm
I am putting my '67 OTS back together after a repaint and I have been prepping the parts before I put them back. Unfortunately, I left this on the workbench and found it yesterday. Of course it was not marked which component it went with. I now can not remember where it goes?
I thought it may be part of the rear engine mount, but it doesn't look like it.
I have just put the front pulleys and alternater on, but I cant see that it would fit there.
It doesnt seem to be part of the transmission mount.
It has a center brass piece that fits into the nut on the bottom and the brass piece is threaded.
Please let me know if you can identify this.
Thanks,
Dan
caveman
#2 Re: What is this part?
Post by caveman » Fri Jul 25, 2025 8:01 pm
It looks like the bulkhead throttle linkage mounting with an adapted brass centre (normally rubber grommet).
1965 S1 4.2 FHC (early)
:wavegreatbritain:
tim wood
#3 Re: What is this part?
Post by tim wood » Fri Jul 25, 2025 8:05 pm
:yeahthat:
dmarsh2426
#4 Re: What is this part?
Post by dmarsh2426 » Fri Jul 25, 2025 9:53 pm
Yes! I believe you are correct.
Thank you so much!
