#1 What is this?
Posted: Thu Feb 17, 2011 12:28 pm
by JagMan
Hi, anyone can tell me what are this "pushers" and which are their function?
Uploaded with
ImageShack.us
Thanks!
Posted: Thu Feb 17, 2011 1:05 pm
by Heuer
They are the rotary controls for ventilation fitted to S1.5 and S2 cars.
Posted: Thu Feb 17, 2011 1:12 pm
by JagMan
Thank you so much!! as you see, I?m a new owner of this piece of art!!
Posted: Thu Feb 17, 2011 9:13 pm
by JagMan
I have two questions more...
What is that switch? which is the function of the side red light???
Uploaded with
ImageShack.us
Another one
Can anyone explain me what is the operation of this light? when would it shine?? I don?t know why it doesn?t work...
Uploaded with
ImageShack.us
Thanks!!!
Posted: Thu Feb 17, 2011 10:32 pm
by PeterCrespin
The second photo shows your choke lamp has come off from behind the dash. It operates whenever the choke is on (provided it is earthed and the bulb, switch and wiring are OK
The first photo shows a non-standard switch and warning lamp so you'll have to trace the wires to see what it controls. Maybe a manual radiator fan switch?
Posted: Fri Feb 18, 2011 1:07 pm
by JagMan
PeterCrespin wrote:The second photo shows your choke lamp has come off from behind the dash. It operates whenever the choke is on (provided it is earthed and the bulb, switch and wiring are OK
Another question, when is on the choke? when is the pusher in "cold position"? or simply, this light shows when you must to change between cold, hot and run mode?
Thanks!!
Posted: Fri Feb 18, 2011 3:34 pm
by mystery type
jagman, if you buy one of these, all the controls ect are explained. you will find it really helpful.
http://cgi.ebay.co.uk/ORIGINAL-JAGUAR-4 ... _689wt_928
#8 Use the FAQ
Posted: Fri Feb 18, 2011 5:38 pm
by andy303
Jagman:
In the meantime, check out the excellent "E-type Knowledge Base" page on this forum. It is packed with a ton of great information. The first chapter of the workshop manual has an explanation of the operating controls, recommended lubricants etc.
http://etypeuk.com/forum/viewforum.php?f=16
#9
Posted: Fri Feb 18, 2011 6:34 pm
by Heuer
As Andy says ..................
Here is an extract to get you going:
