horn operation on column how does it work ?
#1 horn operation on column how does it work ?
Just building up upper column and I can't work out how the horn operates i.e. How the horn push earth etc.
S1 4.2 RHD Bryan
#2 Re: horn operation on column how does it work ?
The centre horn push button presses down on the rod which, in turn, is in contact with Purple/black wire via the brass contact ring in the steering column. The overall column is grounded. Purple and black single bullet locates on copper spring/blade.
#3 Re: horn operation on column how does it work ?
But does the spring and brass contact under the brass like finfured collar not earth the rod ?
S1 4.2 RHD Bryan
#4 Re: horn operation on column how does it work ?
Only when you press the horn button, until then the brass rod is insulated from ground by the white plastic sleeve and contact block.
#5 Re: horn operation on column how does it work ?
I have just checked on Barratts website I am missing the sleve and circip .
S1 4.2 RHD Bryan
