#1 Series 1 clutch/brake reservoirs and missing hoses
Posted: Sun Aug 31, 2025 1:54 pm
I have just picked up a series 1 2+2 that was partially restored by a previous owner before sitting for a while. There are a few oddities in the engine bay that I am trying to figure out.
The first is the 2 fluid reservoirs on the drivers side (RHS - UK car). One is clutch, the other brake. However, the left hand bottle in the pic that has the sensor in the top connects to the clutch master cylinder, and RH reservoir connects to the brake master. Surely the sensor should be on the brake reservoir? What is the correct configuration for a series 1 4.2 car?
Second quick question - I think that there is probably a hose missing from the crankcase breather (I presume) to the airbox:
I presume that the slightly corroded breather should connect to the airbox with a flexi hose?
Thanks!
Thanks!
