What is this?
JagMan
#1 What is this?
Post by JagMan » Thu Feb 17, 2011 12:28 pm
Hi, anyone can tell me what are this "pushers" and which are their function?
Uploaded with ImageShack.us
Thanks!
Post by Heuer » Thu Feb 17, 2011 1:05 pm
They are the rotary controls for ventilation fitted to S1.5 and S2 cars.
JagMan
Post by JagMan » Thu Feb 17, 2011 1:12 pm
Thank you so much!! as you see, I?m a new owner of this piece of art!!
JagMan
Post by JagMan » Thu Feb 17, 2011 9:13 pm
I have two questions more...
What is that switch? which is the function of the side red light???
Another one :roll:
Can anyone explain me what is the operation of this light? when would it shine?? I don?t know why it doesn?t work...
Thanks!!!
Post by PeterCrespin » Thu Feb 17, 2011 10:32 pm
The second photo shows your choke lamp has come off from behind the dash. It operates whenever the choke is on (provided it is earthed and the bulb, switch and wiring are OK
The first photo shows a non-standard switch and warning lamp so you'll have to trace the wires to see what it controls. Maybe a manual radiator fan switch?
JagMan
Post by JagMan » Fri Feb 18, 2011 1:07 pm
PeterCrespin wrote:The second photo shows your choke lamp has come off from behind the dash. It operates whenever the choke is on (provided it is earthed and the bulb, switch and wiring are OK
Another question, when is on the choke? when is the pusher in "cold position"? or simply, this light shows when you must to change between cold, hot and run mode?
Thanks!!
mystery type
Post by mystery type » Fri Feb 18, 2011 3:34 pm
jagman, if you buy one of these, all the controls ect are explained. you will find it really helpful.
http://cgi.ebay.co.uk/ORIGINAL-JAGUAR-4 ... _689wt_928
andy303
#8 Use the FAQ
Post by andy303 » Fri Feb 18, 2011 5:38 pm
Jagman:
In the meantime, check out the excellent "E-type Knowledge Base" page on this forum. It is packed with a ton of great information. The first chapter of the workshop manual has an explanation of the operating controls, recommended lubricants etc.
http://etypeuk.com/forum/viewforum.php?f=16
Andy Blackley
Chardon, Ohio
69 S2 2+2 http://www.xkedata.com/cars/detail/?car=1R41606
Fear God and Dreadnought
Post by Heuer » Fri Feb 18, 2011 6:34 pm
As Andy says ..................
Here is an extract to get you going:
