#1 Coopercraft Vented Front Disc size ?
Posted: Tue Sep 30, 2025 8:36 am
I’m overhauling my front end of the E type this winter - cooling, steering and replacing suspension bushing - and as usual it’s already become a case of “shipwrights disease”, as I start to look at other front end items I could also refresh.
I have Coopercraft Vented front brakes, which I know I fitted Ferodo 522 brake pads in 2005, which my notes say are the same as XJ6 front brake pads. I don’t necessarily need to change the front vented discs - that old “shipwrights disease” is starting to kick in - but for my records, can anyone confirm what front vented disc brake were used on the Coopercraft vented brake kit ?
I also have a note in my records that one time at a Stoneleigh Spares Day, when Coopercraft were then trading, I went to the Coopercraft stand and explained that I had experienced problems fitting my new pads into the Coopercraft brake caliper. They said that on early kits, (circa 1999), that the discs they supplied were too wide. They said that they should have been 21mm wide, but on checking, my discs are nearer 22mm. The Coopercraft front brakes were on the car when I bought it and I found that the previous owner had troubles initially fitting either brake pad, so he had some 1.5mm spacers made to move the caliper over, so at least he could fit the inner pad and milled the outer one down in order to fit it. I removed the spacers so the caliper is now equally spaced on the disc, but although I managed to get the inner pad in - which was very tight - I had to sand the outer pad to get that one in.
If anyone has fitted new vented front discs to their Coopercraft front brakes, I would be grateful for their experiences and what discs they used please ?
