#1 horn operation on column how does it work ?
Posted: Tue Sep 30, 2025 1:19 pm
by phoenix
Just building up upper column and I can't work out how the horn operates i.e. How the horn push earth etc.
#2 Re: horn operation on column how does it work ?
Posted: Tue Sep 30, 2025 3:14 pm
The centre horn push button presses down on the rod which, in turn, is in contact with Purple/black wire via the brass contact ring in the steering column. The overall column is grounded. Purple and black single bullet locates on copper spring/blade.
#3 Re: horn operation on column how does it work ?
Posted: Wed Oct 01, 2025 9:59 am
by phoenix
But does the spring and brass contact under the brass like finfured collar not earth the rod ?
#4 Re: horn operation on column how does it work ?
Posted: Wed Oct 01, 2025 10:36 am
Only when you press the horn button, until then the brass rod is insulated from ground by the white plastic sleeve and contact block.
#5 Re: horn operation on column how does it work ?
Posted: Wed Oct 01, 2025 11:44 am
by phoenix
I have just checked on Barratts website I am missing the sleve and circip .
