I am helping a friend with a RHD Series 1 4.2 FHC 2+2 and it appears the solid Choke cable has broken at the Choke lever end inside the car.
I have removed the parcel shelf under the steering wheel, plus a piece of plastic trim so I can see up to the Choke lever mechanism using my phone in video mode. There is control knob for the under dash air flaps directly under the Choke lever, so access looks very limited.
I am assuming I need to remove the tachometer to enable access to the clamping fixings for the inner and outer cables. If anyone could confirm that this will make the job much easier please ?
Cheers,
Choke cable replacement
#2 Re: Choke cable replacement
Hi Dave from memory yes it will easier with the rev counter out but on my S2 2+2 I took the dash top off..Steve
#3 Re: Choke cable replacement
Dave. I agree with Steve, remove rev counter and dash top and access is very good.
Mike
1969 S2 FHC
1969 S2 FHC
#4 Re: Choke cable replacement
I recently had to adjust the choke light switch because the light would not stay off. Did it by adjusting the cable at the switch as the switch was fully engaged on the mount.
NO need to remove the dash top, just remove the tacho.
Jerome Lunt
2008 MX-5 NC PRHT - now gone
