Exact Diameter Of Lucas "15mm" Dynamo Shafts Please ?
rfs1957
#1 Exact Diameter Of Lucas "15mm" Dynamo Shafts Please ?
Post by rfs1957 » Thu Oct 23, 2025 9:56 am
Steve - can you pull this ?
Doing some more research first.
Thanks.
#2 Re: Exact Diameter Of Lucas "15mm" Dynamo Shafts Please ?
Post by mgcjag » Thu Oct 23, 2025 10:20 am
Don't have e a shaft to measure but this tractor supplier has dimensions..May help https://www.charnleys.com/parts/AMK2886 ... c40/21866/
#3 Re: Exact Diameter Of Lucas "15mm" Dynamo Shafts Please ?
Post by mgcjag » Thu Oct 23, 2025 10:36 am
And shaft measured here
rfs1957
#4 Re: Exact Diameter Of Lucas "15mm" Dynamo Shafts Please ?
Post by rfs1957 » Thu Oct 23, 2025 2:14 pm
I think it may truly be 15mm and not 19/32" as that would be 15.08mm.
My dynamo shaft measures 15.000mm dead (with a good mike) and is unlikely to have lost 0.08 by having the pulley pulled off a couple of times.
