#1 Rear Radius Arm Bushes.
Posted: Fri Dec 19, 2025 5:03 pm
by SimonBrown
Just about to replace my rear radius arm bushes.
From SNGB there is a huge price differential between genuine Jaguar and aftermarket. The smaller bushes are £46.18, or £5.77 each!!
I would normally go for genuine, but with such a difference, would anyone know if it is worth it?
Thank you
#2 Re: Rear Radius Arm Bushes.
Posted: Fri Dec 19, 2025 5:11 pm
by tim wood
I purchased some non original bushes ( not from SNGB) within a couple of years they started to split
Absolute rubbish.
Replaced with those marked metalastic . I say marked as metalastic because in today’s world who knows what’s really genuine. However they have done 5 years without concern
The same occurred with steering rack mounts. I now stick to what I believe to be known brands.
Tim
#3 Re: Rear Radius Arm Bushes.
Posted: Fri Dec 19, 2025 5:16 pm
Hi Simon...Worth checking ebay....SNG sell as British Auto https://ebay.us/m/qUFN1F
#4 Re: Rear Radius Arm Bushes.
Posted: Fri Dec 19, 2025 11:13 pm
Not an easy thing to change if the cheap ones fall apart.
I'd go with genuine.
#5 Re: Rear Radius Arm Bushes.
Posted: Sat Dec 20, 2025 5:35 pm
by Paul bow
Hi.. I used polybush (red) on every bush on my car, the transformation is a great upgrade, def worth the extra expense and will out last all the other rubbish by years.
Rob Beere also sells a quality set of replacement bushes that i have used in the past.
#6 Re: Rear Radius Arm Bushes.
Posted: Sun Jan 04, 2026 11:26 am
by Tjellvar
The poly bush will reduce the famous rear axle steering, specially the big end.
I have used it now for some years.
Also the front end is poly bush that improve handling.
