#1 Otter switch operating temp?
Posted: Tue Dec 30, 2025 3:42 pm
I have recently replaced pretty much the entire cooling system on my series 1 2+2 as the old pipes were corroded having been left empty. I also upgraded to a coolkat fan and a new header tank, with a coolkat solid state otter switch. I ran the car up to temp for the first time today, and the fan doesn't seem to kick in.
If I run the car at idle for 5-10 minutes, it warms up and indicates between 90-100 degrees on the temp gauge on the dash. The radiator and all coolant hoses get hot, and the heater blows hot, indicating that the water pump is circulating water. Yet the fan doesn't come on. A meat thermometer (!) in the header tank indicates around 86-85 degrees C. I then lost my bottle and switched off as I didn't want to let it get too hot.
If I connect the two wires on the otter switch directly, the fan comes on, so I know the wiring and relay are OK.
Is my otter switch faulty, or am I not letting it get hot enough?
